Operating system kernel-level FPGA bridge communication
hi,
By right, the devmem2 must be used to read/write to the HPS2FPGA bridge using the mapping below for Agilex5. I can see that your mapping is incorrect. If you are using the LW HPS2FPGa, it starts at 0x1FC0_0000.
You do not need to create any nodes in the device tree. The nodes in the device tree are only required if you are writing/using SOFT IP Device drivers in Linux kernel to access the bridge. Without drivers and with user-space interface, you should be able to use devmem2.
The bridges will be enabled by default if you do a FPGA configuration in Linux. If you perform this in U-boot, you will have to do a bridge enable in uboot before booting the Linux. The configs that you use above example, CONFIG_FPGA_BRIDGE and _REGION are only required if you are doing FPGA configuration in Linux as they are required by the FPGA manager device driver "stratix10_soc.ko" driver to configure the 2nd stage FPGA core.rbf. In short, the bridges should be enabled if you have configured the FPGA in UBOOT prior to loading Linux.
