Operating system kernel-level FPGA bridge communication
Hi Arun,
It is not clear from the thread if your issue is solved.
To summarize, on Stratix 10 and newer devices, you will not see the bridges as individual entries in the device tree. The bridges can be enabled by running the 'bridge enable' command in U-Boot, which is also invoked automatically when using the 'bootm' with FPGA fabric configuration. The bridges are also automatically enabled when a Linux device tree overaly is applied.
The actul fabric configuration from Linux is similar on all Stratix 10 and newer devices. You can see an example for Agilex 7 here: https://altera-fpga.github.io/rel-25.3.1/embedded-designs/agilex-7/f-series/soc/fabric-config/ug-linux-fabric-config-agx7f-soc/
Please let me know if you still need help with this issue. I can provide a complete example if you let me know exactly what you need.
Thank you,
Radu
Dear Customer,
Since no further clarification is needed on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to the Altera Community Forum and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
Altera Tech Support
