FPGABear
3 months agoAgilex 5E HPS and Linux
Hi. 1. Is there a simple method to run two Linux systems on HPS, i.e.: Linux 1 - 2xA55 and Linux 2 - 2xA76 with different sets of peripherals? 2. Is it possible to use one Ethernet port by these tw...
FPGABear
2 months agoSo, for example, for two Linux systems, you can permanently assign a memory area (another area outside the systems area) with the same physical address, and set the paging of that area to the same size as the area's size?
