wire assignment in verilog
Hello, I have a question while I was writing the code. I made a code wire [15:0] A; and I declared input B; and I declared this signal as assign A = {8{B}};. When I declared this, the top 8 bits of signal A would be filled with 0, so why would it be filled with 0? Shouldn't it be filled with z or x??
- KennyT_altera
I check the Questasim user guide, I couldn't find an option on this warning message enabling. Since this question is more towards EDA, you may log a case to them to further clarify this. https://www.siemens.com/global/en.html, siemens now officially own questasim.
- KennyT_altera
Any further question that you have?
- junyoung2
Then, is there a setting that changes the initial value to x or z, not zero, for the unallocated top 8 bits as in the example above, not a warning message? I wonder how I can check this in the compile stage or in the simulation when the bit width is not correct. Because I automatically assigned 0 for the bit width that is not correct, and if I can't check it in the compile stage or in the simulation, I think this will come to a fatal problem later on.
- KennyT_altera
Since this issue pertains to the usage of Questasim commands (TCL), we will need to consult the relevant team for assistance. I have attempted to find an answer in the Questasim user guide located at W:\24.3\linux\questa_fse\docs, but was unsuccessful. We will get back to you, but it may take some time(1 to 2 weeks). Thank you for your patience.
- KennyT_altera
I just get feedback from Mentor:
For the question regarding warning messages about the bit mismatch, there should be a vopt warning as the example below:
** Warning: (vopt-2241) Connection width does not match width of port 'data_in'. The port definition is at: dut.sv(3).
if you have vopt.log file generated? You may be able to search vopt-2241 and it should have bit-mismatch warning.
They have also consulted with R&D regarding the question on setting that changes the initial value to x or z, not zero.
According to R&D, currently by default:
Unconnected MSB of type reg will be 0, as this is considered as an assignment.
Unconnected MSB of type wire will be Z,
Let me know if the above help?
- KennyT_altera
Is there any further question on this?
- junyoung2
Thank you for your answer.
I have a question for your answer. For input, don't you write the wire type by default? If so, shouldn't the undefined top bits be allocated as Z? Also, I couldn't find a warning message like vopt-2241 even though the bit was not allocated properly (assign D[15:0] = {8{A}};) and the compilation went well. It seems like Modelsim automatically allocates 0 for the unallocated parts, am I right to understand? - KennyT_altera
I will get back to you with an answer by this week.
- RichardT_altera
Please allow us some time to look into.
Thank you for your time and patience.
Richard Tan
- KennyT_altera
Hi, can you check your email for this? As this require long explanation from Questa support.
