YSuzu21's avatar
YSuzu21
1 month ago
Number of ports required for a floating license
I have added the server name and port to license.dat:
SERVER servername  mac address 10000
VENDOR alterad C:\FLEXlm\alterad.exe
# VENDOR mgcld C:\FLEXlm\mgcld.exe
USE_SERVER
I have confirmed that port 10000 is open using Test-NetConnection.
However, even when specifying "10000@servername" in the Quartus License Setup, the "Current license" is not recognized.
The "Current license" is recognized if I temporarily open all ports on the server side, but I cannot keep all ports open permanently.
Are there any other ports required besides port 10000?
Example: Port 10001 is required
VENDOR alterad C:\FLEXlm\alterad.exe PORT=10001
USE_SERVER
Thank you for your assistance.
  • YSuzu21's avatar
    YSuzu21
    Thank you for your reply.
    Is it sufficient to have just one open port?
    Example: 1800
  • YSuzu21's avatar
    YSuzu21
    I have confirmed that the ports are open.
    Since the "Current license" could not be recognized using a single port,I opened three ports.
    VENDOR mgcld C:\FLEXlm\mgcld.exe PORT=10002
    Since the "Current license" was not recognized with just one port,
    The "Current license" was successfully recognized, allowing Quartus to operate normally
    and enabling the compilation to start.
    I plan to continue using it this way, but do you happen to know why more than one port was required?
    I would appreciate your response.
    • ShengN_altera's avatar
      ShengN_altera
      Actually one port will be enough. Could you try replace the port number with other random number? Probably that port 10000 had been repeated and not available
  • YSuzu21's avatar
    YSuzu21
    I tried using ports such as 1800 and 58888, but the license was still not recognized.
    However, the license is recognized and Quartus works correctly when using three ports, so I will continue using it this way.
      ShengN_altera
      Since the license is working correctly with three ports, I think you may continue using it.
  • YSuzu21's avatar
    YSuzu21
    I am incredibly grateful for your continuous support and the detailed answers you have provided for my consultations.
