junyoung2
1 year agowire assignment in verilog
Hello, I have a question while I was writing the code. I made a code wire [15:0] A; and I declared input B; and I declared this signal as assign A = {8{B}};. When I declared this, the top 8 bits of s...
KennyT_altera
1 year agoHi,
I just get feedback from Mentor:
For the question regarding warning messages about the bit mismatch, there should be a vopt warning as the example below:
** Warning: (vopt-2241) Connection width does not match width of port 'data_in'. The port definition is at: dut.sv(3).
if you have vopt.log file generated? You may be able to search vopt-2241 and it should have bit-mismatch warning.
They have also consulted with R&D regarding the question on setting that changes the initial value to x or z, not zero.
According to R&D, currently by default:
Unconnected MSB of type reg will be 0, as this is considered as an assignment.
Unconnected MSB of type wire will be Z,
Let me know if the above help?
