11 years agoVHDL and process : several sensivity signals
I have a problem with the following structure of process : process(clk, signal) begin if rising_edge(signal) then -- code1 end if; if rising_edge(clk) then -- code2 end if; end process; It seems that after SIGNAL = '1', the rising_edge(SIGNAL) is always true at each CLK'event, and I endlessly enter in the CODE1 part... I can't figure out what's wrong with that code ? Thank you for your help !6 Replies
Where are you having the problem? in simulation or hardware? this code is not suitable for FPGAs, as multiple clocks are not allowed.
Why not post the code with the problem. The situation you describe is not possible with the code snippet you posted - you need to post the whole code. - Altera_Forum
Thank you very much for your answer Tricky, I am having the problem in hardware :
CODE1 does the following : - It sets a flag and reset a counter. CODE2 does the following : - If the flag is set, it increments a counter. When the counter reaches its maximum, it resets the counter and resets the flag. Then, we have to wait until CODE1 sets the flag to enter in CODE2. The problem is that when I set "SIGNAL", the counter increases and decreases randomly around a random value : As if counter was constantly reset from CODE1. Here is the code : --------------------------- CODE1 : flag <='1'; CODE2 : if (flag = '1') then if(counter < max) then counter := counter + 1; else counter := 0; flag <= '0'; end if; end if; --------------------------- But you've answered my question : multiple clocks (multiple "rising_edge" tests) are not allowed, which could explain such erratic behavior. I have to think of another way to implement my code. Thank you again for your help. - Altera_Forum
If it got to hardware, it would have actually used your code. If it did think there were actually 2 clocks, it would have caused and error.
I finally found a solution ! To whom it may help :
What I wanted to do (the following code DOES NOT work) : process(CLK, SIGNAL) begin if rising_edge(SIGNAL) then flag <='1'; end if; if rising_edge(CLK) then if (flag = '1') then if(counter < max) then counter := counter + 1; else counter := 0; flag <= '0'; end if; end if; end if; end process; The solution I've found (the following code SEEMS to work) : process(CLK, SIGNAL) begin if (SIGNAL='1' and flag = '0' ) then flag <= '1'; flag2 <= '1'; elsif(SIGNAL='0') then flag <= '0'; elsif rising_edge(CLK) then if(flag2 = '1') then -- CODE flag2 = '0'; end if; -- CODE end if; end process; - Altera_Forum
you are missing "flag" from the first code sensitivity list. This mean's you'll have a missmatch between the simulation and the actual code on hardware.
What you need to do is build an edge detector - simply register signal and compare it to the incoming value:signal sig_r : std_logic; process(clk) begin if rising_edge(clk) then sig_r <= sig; if sig_r = '0' and sig = '1' then --check for rising edge of SIGNAL flag <= '1'; else --etc end if; end if; end process; - Altera_Forum
You don't use "rising_edge" twice or more in your code.
