11 years agoVHDL and process : several sensivity signals
Hi, I have a problem with the following structure of process : process(clk, signal) begin if rising_edge(signal) then -- code1 end if; if rising_edge(clk) then ...
11 years agoI finally found a solution ! To whom it may help :
What I wanted to do (the following code DOES NOT work) : process(CLK, SIGNAL) begin if rising_edge(SIGNAL) then flag <='1'; end if; if rising_edge(CLK) then if (flag = '1') then if(counter < max) then counter := counter + 1; else counter := 0; flag <= '0'; end if; end if; end if; end process; The solution I've found (the following code SEEMS to work) : process(CLK, SIGNAL) begin if (SIGNAL='1' and flag = '0' ) then flag <= '1'; flag2 <= '1'; elsif(SIGNAL='0') then flag <= '0'; elsif rising_edge(CLK) then if(flag2 = '1') then -- CODE flag2 = '0'; end if; -- CODE end if; end process;
