error in JTAG server (error code 35) and autodetect (unable to scan device chain) Quartus 18.1
Hello fellow members,
I have a Max10 FPGA Evaluation Kit board (10M08SAE144C8G) which i want to flash via JTAG. For this, i have installed Quartus Prime (18.1 version) and have USB Blaster 2 as an interface. After connecting the hardware, the LEDs on the board are stable. When i execute autodetect on the programmer , i get a dialog box stating "unable to scan device chain . Hardware is not connected"(screenshot attached). In the hardware setup , i coulkd see the usb blaster variant is added but still this error occurs. Similary when i try to run the .pof file , the diagnosis show "unexpected error in JTAG server -- error code 35" (screenshot attached).
I checked the driver and it seems the USB blaster driver is also updated. On the command prompt, it shows
1) USB-Blaster variant [USB-1]
Unable to lock chain - Hardware not attached
Has someone encountered this issue before. Any help or suggestion would be highly appreciated.
The screenshots can be seen in the attachments.
Ali
- FakhrulA_altera
Hi Ali789,
Could you try to perform this:
https://www.macnica.co.jp/en/business/semiconductor/support/faqs/altera/114785/
Fakhrul - FakhrulA_altera
As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Altera experts. Otherwise, community users will continue to assist you here. Thank you.
