11 years agoVHDL and process : several sensivity signals
Hi, I have a problem with the following structure of process : process(clk, signal) begin if rising_edge(signal) then -- code1 end if; if rising_edge(clk) then ...
11 years agoyou are missing "flag" from the first code sensitivity list. This mean's you'll have a missmatch between the simulation and the actual code on hardware.
What you need to do is build an edge detector - simply register signal and compare it to the incoming value:
signal sig_r : std_logic;
process(clk)
begin
sig_r <= sig;
if sig_r = '0' and sig = '1' then --check for rising edge of SIGNAL
flag <= '1';
else
--etc
end if;
end if;
end process;
