Quartus/Signaltap complains about wrong version
we are using Quartus prime V24.1.0 for a rather large project. We have various signaltap files stored within git for analysis. Now, from time to time, it happens that quartus throws the following warning/assertion. Obviously, this assertion can be suppressedwith ENABLE_VHDL_STATIC_ASSERTIONS OFF, and everything is working. However this is no soulution as we want to have ENABLE_VHDL_STATIC_ASSERTIONS ON
Error (22148): VHDL error at sld_ela_control.vhd(1263): Failure: "The design file sld_ela_control.vhd is released with Q
uartus Prime software Version 24.1.0. It is not compatible with the parent entity. If you generated the parent entity us
ing the Signal Tap megawizard, then you must update the parent entity using the megawizard in the current release.": exi
ting elaboration File: c:/intelfpga_pro/24.1/quartus/libraries/megafunctions/sld_ela_control.vhd Line: 1263If I remove the signaltap(file) entirely, and readd it, everything works. However, this is very annoying and time consuming.
Q1. Why is this assertion triggered in the first place? We do not use any other versions.
Q2. How do I "update the parent entity using the megawizard"? I'm unable to find an "update" option. To me deleting signaltap and re-creating it is not an update....
Michael
- sstrell
Are you using the IP Catalog flow for adding Signal Tap to your design instead of simply creating and adding the .stp file to your project? If so, did you create Signal Tap in a previous version of Quartus? Perhaps you need to regenerate the IP.
Explain in more detail how you created Signal Tap and how you're using it.
- MichaelL
for new signaltaps I'm clicking in quartus 24.1 on Tools => Signaltap Tap Logic Analyzer and then adding the nodes and instances.
What now happend was that, I deactivated the signaltap in the .qsf-file, (did a synthesis), then readded it in the qsf (the stp-file hasn't been changed), reopend signaltap (using Tools => Signal Tap Logic Analyzer), added some more nodes; did a new synthesis and the above assertion happened.How to I regenerate the IP, I thought this will happen automatically, as "set_global_assignment -name PROJECT_IP_REGENERATION_POLICY ALWAYS_REGENERATE_IP" is on.
As for older signaltaps we simply add the stp-file (and activate it) in the qsf - Here, I can somehow understand that this might not be optimal, still the question is, what and how to update there, as "set_global_assignment -name PROJECT_IP_REGENERATION_POLICY ALWAYS_REGENERATE_IP" is on.
Is there any way to manually update the signaltap?Michael
- sstrell
You're not using the IP Catalog flow, so you don't have to worry about regenerating the IP.
If you're just adding the .stp as a design file, then this could be an issue. Use the setting in the Settings dialog box in the Signal Tap settings to enable/disable the .stp file. The wrong assignment is probably being put in the .qsf if you're doing it manually.
- MichaelL
I just removed and readded the stp file using the dialog:
Still, I get the following error:
So, is there any way to get this working, without creating a new stp-file?
- RichardT_altera
Which Quartus Edition are you using—Standard or Pro?
Does creating a new .stp file in your project (version 24.1) also cause this issue?
Do you know when this .stp file was originally created and which Quartus version was used?
Could you share your design .qar file (via Project > Archive Project) that can reproduce this error?
Richard Tan
- sstrell
It is possible your .stp file is corrupted. I'd try recreating it.
- RichardT_altera
Do you have any further update regarding this case?
Richard Tan - sstrell
Try turning off the "Enable Signal Tap Logic Analyzer" checkbox from the settings and do a full compile (not just synthesis). Then turn it back on and do another full compile. If this was a brand new .stp file, your error doesn't make sense.
- MichaelL
Sry. I was not precise in my post: I did a full compile (even removed generated files) including regenerating all IP files and not only the synthesis step. However, I will try turning off/on the checkbox.
- MichaelL
sstrell Unfortunately, this had no effect.
Error(22148): VHDL error at sld_ela_control.vhd(1263): Failure: "The design file sld_ela_control.vhd is released with Quartus Prime software Version 25.3.0. It is not compatible with the parent entity. If you generated the parent entity using the Signal Tap megawizard, then you must update the parent entity using the megawizard in the current release."
Still what's very odd, that obviously this is only a (wrongfully triggered) assertion... When deactivating "static assertion support" everything "works" - however deactivating static assertion support is not what we want in our environment
- sstrell
How is your .stp file set up? Is there anything unusual about it? I've never seen issues like this before with the .stp file flow.
Is the static assertions setting you mention an assignment you've created in the Assignment Editor?
- MichaelL
sstrell My stp. file is straight forward; it was created with the gui: Multiple signals, one trigger window, two triggers (AND and OR). However, what I did change was to add (and remove) a power-up trigger. However this was the first time, I used a power-up-trigger, but I don't think this is the root cause, because previously the same problems (with version 24.3) existed, and there was no power-up trigger
Yes, these settings enable Evaluation of the above mentioned assertion. If I deactivate them (never tried VHDL and SV individually) and cause the failure.
P.S. Please be aware, that I'm ooo from 13. Feb to 13 Mar, so please don't close this threat in the meanwhile!
- RichardT_altera
Could you share your .qar design (Project > Archieve Project) so we can see if we can try to duplicate the issue.
Currently we do not have any idea what could be the cause. This might need debugging.
Do you have a different machine to test if the issue persists?
Also, which operating system are you currently using?
For reference, here are the tool versions and error details involved:Quartus Software: With Quartus Pro 25.3 (patched)
Device Family: Arria 10 devices
Error Message:
Debug done:
1. Run using Administrator privileges - no change
2. Deleted qdb/dni folder - no changeLet me know if I missed any information.
Richard Tan
- RichardT_altera
Hi MichaelL
It appears that the IP versioning mechanism has not been properly maintained in the Quartus software. Our tool specialist will fix this issue in a future Quartus release, starting from version 26.1.1. Unfortunately, there is currently no workaround for this error.
Richard Tan- MichaelL
thanks for looking into this issue. I'd hoped for a quick fix, but at least it is good to know that there is nothing we can do atm.
Michael
- RichardT_altera
MichaelL Are you ok to wait for the Quartus 26.1.1 release?
FYR, the Quartus 26.1.1 is scheduled to be release on July–August 2026 time frame.
Richard Tan
- RichardT_altera
MichaelL
With the issue planned to be fixed in a future Quartus version (v26.1.1) and no further action required from our side, we will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Richard Tan - RichardT_altera
MichaelL I’ve confirmed that Quartus 26.1.1 does not support Arria 10 devices, so you will not be able to use this design with version 26.1.1.
You may need to wait for the Quartus 26.3 release instead.
Sorry for the inconvenience caused.
RichardT_altera thanks for letting us know and thank you very much for your assistance!
