8 years ago
Timing Violations workaround strategy
Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations.
In this connection I have one question - does exist some straightforward approach on working around "timing violations" ?
For example on the image below there are 2 screenshots form TimeQuest:
  • top screenshot - results of "Report Top Failing Paths"
  • bottom screenshot - "Peport Timing" for the path, highlighted in yellow on the top screenshot
So, in order to workaround timing violations on SDRAM data bus (blue cadre on the top screenshot) should I proceed with set_multicycle_path, e.g.:
set_multicycle_path -setup -to [get_pins {nios_led2_sdram:u0|nios_led2_sdram_sdram:sdram|za_data
[*]}] 2
set_multicycle_path -hold -to [get_pins {nios_led2_sdram:u0|nios_led2_sdram_sdram:sdram|za_data
[*]}}] 1
or there are other solutions ?
Thanks in advance.
https://alteraforum.com/forum/attachment.php?attachmentid=13535&stc=1
