9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years ago --- Quote Start --- Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. --- Quote End --- 1. Check if there are any ignored constrains. 2. Check if there are any unconstrained paths. 3. Check clock transfers and make sure that there are no invalid clock transfers analysed. --- Quote Start --- Does exist some straightforward approach on working around "timing violations" ? --- Quote End --- It depends what causes those timing violations. Violations between unrelated clocks or paths - usually can be solved by setting clock groups or setting false path between unrelated paths. Violations in register-to-register level - usually caused by bad coding style, go back to your VHDL/Verilog code and fix it. Violations in I/O - can be solved by using PLL and clock phase shift, clock inversion ect.
