9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years agoFirst, thank you for feedback Ryan.
My case seems to be quite simple ... instantiation of one Qsys module. The Qsys module consists of (please have a look at Qsys screenshot below):- CPU
- PLL, that generates 2 clocks (1st – for all internal blocks, including CPU, 2nd – for external SDRAM)
- SDRAM controller, connected to external SDRAM
- GPIOs (buttons, switches, LEDs, 7-segment LEDs)
- 2 timers
module nios_led2_top (input clk,
input sw,
input key,
output led,
output hex3, hex2 , hex1, hex0,
output sdram_addr,
inout sdram_dq,
output sdram_bank,
output sdram_cas_n, sdram_ras_n, sdram_cke, sdram_cs_n, sdram_clk,
output sdram_dqmh, sdram_dqml, sdram_we_n);
wire sseg;
assign hex3 = sseg;
assign hex2 = sseg;
assign hex1 = sseg;
assign hex0 = sseg;
nios_led2_sdram_10leds u0 (
.btn_export (key),
.clk_clk (clk),
.led_export (led),
.reset_reset_n (1'b1),
.sdram_wire_addr (sdram_addr),
.sdram_wire_ba (sdram_bank),
.sdram_wire_cas_n (sdram_cas_n),
.sdram_wire_cke (sdram_cke),
.sdram_wire_cs_n (sdram_cs_n),
.sdram_wire_dq (sdram_dq),
.sdram_wire_dqm ({sdram_dqmh, sdram_dqml}),
.sdram_wire_ras_n (sdram_ras_n),
.sdram_wire_we_n (sdram_we_n),
.sseg_export (sseg),
.switch_export (sw),
.clk_sdram_clk (sdram_clk)
endmodule
The frequency of two PLL-generated clocks is 3 times input frequency (which is 50MHz). One of the clocks (that which clocks external SDRAM) is shifted -3.5ns in regard to another. I'm not sure if it's the optimal solution … this configuration I've adopted from a reference design of my board. Here is the content of the .sdc file: create_clock -name clk -period 20
create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
derive_pll_clocks
derive_clock_uncertainty
set_input_delay -clock altera_reserved_tck -clock_fall 3
set_output_delay -clock altera_reserved_tck 3
create_generated_clock -name clk_ext_sdram -source .gpll~PLL_OUTPUT_COUNTER|divclk}]
set_false_path -to
# Constraint SDRAM DATA for input
set_input_delay -clock clk_ext_sdram -max 0 ]
set_input_delay -clock clk_ext_sdram -min 0 ]
# Constraint SDRAM DATA for output
set_output_delay -clock clk_ext_sdram -max 0 ]
set_output_delay -clock clk_ext_sdram -min 0 ]
# Constraint DRAM ADDRESS for output
# Constraint SDRAM Controlss for output
set_output_delay -clock clk_ext_sdram -max 0 sdram_dqm* sdram_cas_n sdram_ras_n sdram_cke sdram_cs_n sdram_we_n}]
set_output_delay -clock clk_ext_sdram -min 0 sdram_dqm* sdram_cas_n sdram_ras_n sdram_cke sdram_cs_n sdram_we_n}]
set_multicycle_path -setup -to }] 2
set_multicycle_path -hold -to }] 1
set_false_path -from
set_false_path -from * -to
In this constraint file I derived PLL clocks and used one of them to constraint SDRAM data, address and control signals (e.g. cs_n, cke, etc.). Doubtless, the constraints I imposed are erroneous … as Timing Analysis reported a lot of violations. These violations I've tried to repair with help of multicycles (again, perhaps, it's not the best solution for such issues). Anyway these multicycles constraints were ignored. Is it possible, just looking at the constraint file (and taking into count the information from Qsys) do the first estimation what is wrong with constraints ? Perhaps, correcting some basic errors can avoid the majority of timing violations. And then (after repairing big blunders) pass to timing analysis using TimeQuest reports?
