11 years ago
System Verilog: Can´t change value of a "struct" variable
I´m newbie on Verilog, actually also in System Verilog, but worked long time ago with VHDL and C++ languages.
I used a template of a Moore state machine from ALTERA for Verilog, and performed some changes in order to start the learning.
However, during simulation, I can´t see any change at both the variables currentstate.level_main and currentstate.level_sub. I took the care to perform reset during simulation.
module moore_mac
    input    clk, data_in, reset,
    output reg  data_out
    reg  sub_state3, state ;
    parameter   S0   = 3'b000, S1   = 3'b001, S2   = 3'b010, S3   = 3'b011 ;
    parameter   S3_0 = 3'b100, S3_1 = 3'b101, S3_2 = 3'b110                ;
    typedef enum { SM0  , SM1  , SM2  , SM3   } STATE_MACHINE   ;
    typedef enum { SM0_S, SM1_S, SM2_S, SM3_S } STATE_MACHINE_S ;
    typedef struct {
       reg  Level_main ;
       reg  Level_sub ;
    } FSM ;
    FSM     CurrentState ;
    // Determine the next state
    always @ ( posedge clk or posedge reset )
        begin
            if (reset)
                begin
                    state         <= S1   ;
                    sub_state3    <= S3_0 ;
                    CurrentState.Level_main <= S0   ;
                    CurrentState.Level_sub  <= S3_0 ;
                end
            else
                case (state)
                    S0:
                                     state            <= S1;
                    S1:
                        if (data_in) state         <= S1;
                        else         state         <= S2;
                    S2:
                        else         state         <= S3;
                    S3:
                                     state <= next_state ( sub_state3 ) ;
                endcase
        end
    // Output depends only on the current state
    always @ (state)
        begin
            case (state)
                S0:
                    data_out = S0 ;
                S1:
                    data_out = S1 ;
                S2:
                    data_out = S2 ;
                S3:
                    data_out = S3 ;
                default:
                    data_out = S0 ;
            endcase
        end
//  Gets next state, by assessing corresponding sub_state
    function  next_state  ;
        input reg  valSubstateBefore  ;
              reg  valSubstateAfter   ;
        if ( valSubstateBefore < S3_2 )
            begin
                valSubstateAfter = valSubstateBefore + 1 ;
                state = state ;
            end
        else
            begin
                valSubstateAfter = S3_0 ;
                state = S0 ;
            end
        sub_state3 = valSubstateAfter     ;
        next_state = state ;
    endfunction
endmodule
Thanks in advance.
Andre
