11 years agoI´m currently using the structure bellow at a function that handles both its inputs and outputs as type fsm_t.
typedef struct packed {
bit Level_main_t ;
bit Level_sub_t ;
bit Level_subcurr_t ;
} FSM_t ; That is something like that: function FSM_t next_state ( input ...)
FSM_t next_state_return ;
return next_state_return ;
endfunction Once I need to use at the block a reg variable having the same format to exchange values, I performed the following : typedef struct packed {
reg Level_main ;
reg Level_sub ;
reg Level_subcurr ;
} FSM ; ...and created the variable bellow: FSM StateMachine ; However, I don´t like the above code arrangement, due I employed a structure duplicated with the same format. Does it have any way to perform such a declaration on a smarter way, as for example with only the type fsm_t ?
