11 years agoI had some problems to activate Modelsim license due to issues regarded to system environment variables. Anyway, I decided to work with the simulation performed on synthesised version of the code, due I´m assuming that this could yield a more realistic result, once runs directly into the technology on what will be assembled.
Back to the code, I wish ask a new question, now related to struct usage on functions, more specifically: how to use a 'struct' variable into a function, either as input and output ? I´m using the code bellow, which has few enhancements on the other posted before. The function next_state instantiated at line 71, and declared at the line 97 which according to lines 115-116 has output of the type fsm_t, do not update correctly its values. I´m convinced that I did not performed the correct association of inputs at the lines 98-99. due do match to the same fsm_t type used at the output. Could so please inform what I´m doing wrong, or just suggest a link were I could learn how could I create and instantiate a function using a struct variable at input and output ? Many thanks in advance.//`define DEBUG_MODE
module moore_mac
input clk, data_in, reset,
output reg data_out
//******************************* Parameter definitions
typedef enum logic { SM0, SM1, SM2, SM3, SM3_0, SM3_1, SM3_2, SM3_3 } fmstate ;
fmstate nstate, pstate ;
parameter S0 = 3'b000 ;
parameter S1 = 3'b001 ;
parameter S2 = 3'b010 ;
parameter S3 = 3'b011 ;
parameter S3_0 = 3'b100 ;
parameter S3_1 = 3'b101 ;
parameter S3_2 = 3'b110 ;
parameter S3_3 = 3'b111 ;
//******************************* Type declarations
typedef struct packed {
reg Level_main ;
reg Level_sub ;
} FSM ;
bit Level_main_t ;
bit Level_sub_t ;
} FSM_t ;
//******************************* Varable declarations
FSM_t tempCurrentState ; // State machine index ( temporary )
FSM CurrentState ; // State machine index ( current )
//`ifdef DEBUG_MODE
reg Debug_counter ;
//`endif
//********************************** Determine the next state
always @ ( posedge clk or posedge reset )
begin
if (reset)
begin
//`ifdef DEBUG_MODE
Debug_counter <= 0 ;
//`endif ;
CurrentState.Level_main <= S0 ;
CurrentState.Level_sub <= S3_0 ;
end
else
begin
//`ifdef DEBUG_MODE
Debug_counter <= Debug_counter + 1 ;
//`endif
case (CurrentState.Level_main)
S0:
CurrentState.Level_main <= S1;
S1:
if (data_in) CurrentState.Level_main <= S1;
else CurrentState.Level_main <= S2;
S2:
else CurrentState.Level_main <= S3;
S3:
CurrentState <= next_state ( CurrentState.Level_main , CurrentState.Level_sub ) ;
endcase
end
end
//********************************** Determine the output value
always @ ( CurrentState.Level_main )
begin
case ( CurrentState.Level_main )
S0:
data_out = S0 ;
S1:
data_out = S1 ;
S2:
data_out = S2 ;
S3:
data_out = S3 ;
default:
data_out = S0 ;
endcase
end
// Gets next state, by assessing corresponding sub_state
function FSM_t next_state ;
input reg valStateBefore ;
input reg valSubstateBefore ;
reg valStateAfter ;
reg valSubstateAfter ;
if ( valSubstateBefore < S3_3 )
begin
valStateAfter = valStateBefore ;
valSubstateAfter = valSubstateBefore + 1 ;
end
else
begin
valStateAfter = S0 ;
valSubstateAfter = S3_0 ;
end
next_state.Level_main_t = valStateAfter ;
next_state.Level_sub_t = valSubstateAfter ;
endfunction
endmodule
note: Please consider the fact that this code is only a temporary draft, so that some small problems flagged by the compiler as "Warnings" will be fixed later.
