10 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. A pattern is driven onto the 20-bit TX parallel input but the RX parallel output remains all 0s. The rx_is_lockedtoref and rx_is_lockedtodata signals are asserted and the various resets to the transceiver are deasserted. It appears that all conditions are good.
In the simulation I am seeing this message: # [alt_xcvr_reconfig_soc.v] Full model disabled I do not really know what this message means. A search of Altera's website does not result in any information. My fear is that something is missing from the simulation fileset that results in the RX PMA being non-operational in the simulation. Is it even possible to run a functional simulation of the StratixV transceivers? I never had a problem running a functional simulation of the StratixIV transceivers.
