11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years agoI am using the Native PHY with only the phase compensation FIFOs enabled in the PCS layer. The parallel data is 20-bits. The parallel data clock is 300 MHz. There are no ports with the names you are requesting. My simulation shows all resets deasserted, all busy signals deasserted, wiggles on rx_serial_data but no wiggles on rx_parallel_data.
This editor appears to have turned all instances of ), into some smiley face... XCVR_BASIC_6GBPS XCVR_BASIC_6GBPS ( .pll_powerdown ( pll_powerdown ), .tx_analogreset ( altgx_tx_analog_reset), .tx_digitalreset ( altgx_tx_digital_reset ), .tx_pll_refclk ( pma_ref_clk, .tx_serial_data ( altgx_tx_data_out , .pll_locked ( altgx_tx_pll_locked , .rx_analogreset ( altgx_rx_analog_reset , .rx_digitalreset ( altgx_rx_digital_reset , .rx_cdr_refclk ( pma_ref_clk , .rx_serial_data ( altgx_rx_data_in , .rx_is_lockedtoref ( altgx_rx_pll_locked , .rx_is_lockedtodata ( altgx_rx_freq_locked &, .tx_std_coreclkin ( clk_300 ), .rx_std_coreclkin ( clk_300 ), .tx_std_clkout ( altgx_tx_clk_out , .rx_std_clkout ( , .tx_cal_busy ( tx_cal_busy , .rx_cal_busy ( rx_cal_busy , .reconfig_to_xcvr ( reconfig_to_xcvr , .reconfig_from_xcvr ( reconfig_from_xcvr , .tx_parallel_data ( altgx_tx_data_in , .unused_tx_parallel_data ( 44'd0 , .rx_parallel_data ( altgx_rx_data_out , .unused_rx_parallel_data ( ;
