11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years agoDave is right. The Qsys work with PHY IP cores which was introduced for the V generation devices. For the IV generation, the transceiver is still running with ALTGX which is not supported by Qsys.
