11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years agoHi Michael,
By the way, what are the status of rx_ready and rx_syncstatus? What is the PHY IP that you are using?
