11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years agoTake a look at the transceiver toolkit documents I wrote here;
https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html The second shows how to use the Arria V GZ Transceivers, which are identical to those on the Stratix V (the code is the same). Go through that tutorial, and then modify it for your use. There is a simulation testbench in there. Cheers, Dave
