12 years agoSRAM IP that work on some builds, and some it doesn't!
Hello All!
I'm having an issue implementing some VERY simple IP for an asynchronous SRAM chip (on digikey: http://www.digikey.com/product-detail/en/is61wv25616bll-10bli/706-1104-nd/1831380). It's really making me doubt myself. It's just a dumb bit of code, that's I've used years ago on an old project (Quartus II 9.1 I think) module sram( // global clk/reset clk, reset_n, // avalon slave s_chipselect_n, s_byteenable_n, s_write_n, s_read_n, s_address, s_writedata, s_readdata, // SRAM interface SRAM_DQ, SRAM_ADDR, SRAM_UB_n, SRAM_LB_n, SRAM_WE_n, SRAM_CE_n, SRAM_OE_n ); parameter DATA_BITS = 16; parameter ADDR_BITS = 18; input clk; input reset_n; input s_chipselect_n; input [(DATA_BITS/8-1):0] s_byteenable_n; input s_write_n; input s_read_n; input [(ADDR_BITS-1):0] s_address; input [(DATA_BITS-1):0] s_writedata; output [(DATA_BITS-1):0] s_readdata; output SRAM_CE_n; output SRAM_OE_n; output SRAM_LB_n; output SRAM_UB_n; output SRAM_WE_n; output [(ADDR_BITS-1):0] SRAM_ADDR; inout [(DATA_BITS-1):0] SRAM_DQ; assign SRAM_DQ = SRAM_WE_n ? 'hz : s_writedata; assign s_readdata = SRAM_DQ; assign SRAM_ADDR = s_address; assign SRAM_WE_n = s_write_n; assign SRAM_OE_n = s_read_n; assign SRAM_CE_n = s_chipselect_n; assign {SRAM_UB_n,SRAM_LB_n} = s_byteenable_n; endmodule [/INDENT] That's it, just 54 lines with white space. The issue I'm having is that:- Using Quartus II 12.1 Build 177, I will build the project, and it works 100%.
- Then, I'll change something very very simple in the Verilog, recompile and find that my Nios2 will not run - and gives me a verify failed error:
- https://mail.google.com/mail/u/1/?ui=2&ik=13b831dd1d&view=att&th=13e8b81cdbc4b34e&attid=0.0.1&disp=emb&realattid=ii_13e8b7772d7b4a5d&zw&atsh=1
- The change can be as simple as moving a single output to a different pin on the device, and then nios2 just won't execute for SRAM verify failure. I'm losing my cool by this point.
- Now, if I go back to Quartus and just hit *compile* again, without making any changes at all, the new SOF works fine, Nios2 verifies and runs from SRAM... really lost my cool now.
