12 years agoThanks DSL,
I've tried that, with this code, which has the same behaviour:
module sram
// global clk/reset
input wire clk,
input wire reset_n,
// avalon slave
input wire s_chipselect_n,
input wire s_byteenable_n,
input wire s_write_n,
input wire s_read_n,
input wire s_address,
input wire s_writedata,
output wire s_readdata,
// SRAM interface
inout wire SRAM_DQ,
output reg SRAM_ADDR,
output reg SRAM_UB_n,
output reg SRAM_LB_n,
output reg SRAM_WE_n,
output reg SRAM_CE_n,
output reg SRAM_OE_n
parameter DATA_BITS = 16;
parameter ADDR_BITS = 18;
// internal registers
reg writedata_reg;
// combinatorial outputs
assign SRAM_DQ = SRAM_WE_n ? 'hz : writedata_reg;
assign s_readdata = SRAM_DQ;
// synchronous registers
always @ ( posedge clk )
begin
if ( s_chipselect_n == 0 ) // if this component selected
begin
writedata_reg <= s_writedata; // register the write data off the bus
SRAM_ADDR <= s_address; // clock through other outputs to sram
SRAM_WE_n <= s_write_n;
SRAM_OE_n <= s_read_n;
SRAM_CE_n <= s_chipselect_n;
{ SRAM_UB_n,SRAM_LB_n } <= s_byteenable_n;
end
end
endmodule
What SignalTap is tell me, is that there is no chip select, no write and no read signal. So the bus is trying to read from the SRAM address space, but the control signals are not being asserted... In Nios I'm looping a memory test over the SRAM space. Could this be a problem on the avalon bus side of things? Is my code being optimised out for some reason?
