REMOVE_REDUNDANT_LOGIC_CELLS is important, take care.
Pay attention to leave the REMOVE_REDUNDANT_LOGIC_CELLS option to ON if you are using a reconfig pll [at least in stratix 3 FPGA].
Turning the option OFF makes 3 redundant cells not removed and the PLL fails to produce aproper clock after reconfiguration.
File is altpll_reconfig_quartus.vhd,
SIGNAL cuda_combout_wire : STD_LOGIC_VECTOR (3 DOWNTO 0);
--Quartus VERSION 13.1
- KennyT_altera
Can you circle out the different base on your screenshot?
I will try it on Q18.1 to see if the problem still exist.
- AEsqu
Contributor
Please see the diff in the new attachment.
- AEsqu
Contributor
Please note that timings are meet for setup and hold in both scenario's,
so this is not timing related (slack of +0.3 ns).
If you need the qar to reproduce it, let me know (give me your personal placeholder as I cannot give it on the forum).
Please note that I will stick to v13.1 (last supported version for the stratix III fpga).
- KennyT_altera
I had send you a separate mail for the qar. you may check your inbox
- AEsqu
Contributor
So, what is the outcome KTan9?
Is the issue still present?
- KennyT_altera
Sorry, I had been quite busy. I will test it by today.
- KennyT_altera
Given that this bugs is in the older version of Quartus Prime, this bug/issue is currently in the lower priority list for Intel to fix. We apologize for any inconvenience.
- AEsqu
Contributor
I removed manually in the RTL code the lines cuda_combout_wire as sometime quartus was still not removing them for some reason.
Now it works fine.
- AEsqu
Contributor
I'm re-using this code again and faced the same issue (of course),
but as I wanted to use that option globally to preserve the netlist from Synplify and preserve my clock nets name point,
I'm now using this in the .qsf:
#No global optimization
set_global_assignment -name REMOVE_REDUNDANT_LOGIC_CELLS OFF
#But this is required otherwise the variable PLL clock is not working
set_instance_assignment -name REMOVE_REDUNDANT_LOGIC_CELLS ON -to "adjustable_pll:adjustable_pll_inst"
