AEsqu
Contributor
7 years agoREMOVE_REDUNDANT_LOGIC_CELLS is important, take care.
Hi, Pay attention to leave the REMOVE_REDUNDANT_LOGIC_CELLS option to ON if you are using a reconfig pll [at least in stratix 3 FPGA]. Turning the option OFF makes 3 redundant cells not removed and...
AEsqu
Contributor
4 years agoI'm re-using this code again and faced the same issue (of course),
but as I wanted to use that option globally to preserve the netlist from Synplify and preserve my clock nets name point,
I'm now using this in the .qsf:
#No global optimization
set_global_assignment -name REMOVE_REDUNDANT_LOGIC_CELLS OFF
#But this is required otherwise the variable PLL clock is not working
set_instance_assignment -name REMOVE_REDUNDANT_LOGIC_CELLS ON -to "adjustable_pll:adjustable_pll_inst"
