10 years agoQuartus Router Congestion
Hello all,
I have a Cyclone V A9 device (300k LEs) and a big design that fit it 95% ALM 12% Memory bits 37% DSP. 14% of ALM are unavailable due to LAB input limits and wide-signals conflicts so real used space is 81% of ALM. Compilation fail due to Warning (16618): Fitter routing phase terminated due to routing congestion. Congestion details can be found in Chip Planner. Critical Warning (188026): The Fitter failed to successfully route the design. You may be able get this design to route by making design modifications, changing the fitter seed or by enabling the Fitter Aggressive Routability Optimizations logic option. etc.. Attached a Chip Planner blank and with congestion map. Threshold is at 99%, why in black area (= no my logic) there is a congestion? What is in that area (circled yellow into images)? I am trying to change some settings and floorplanning design but every compilation take 1+ hour (I use .vqm file generated by another tool so analysis and synthesis is fast, i do just routing) Image link: http://it.tinypic.com/r/2wecbdk/9 Thank you
