10 years agoQuartus Router Congestion
Hello all, I have a Cyclone V A9 device (300k LEs) and a big design that fit it 95% ALM 12% Memory bits 37% DSP. 14% of ALM are unavailable due to LAB input limits and wide-signals conflicts so...
10 years agoIf you have as long as you like, then make the calculation use time division multiplex. eg. use one multipler to calculate 8 different values in 8 clocks rather than 8 multipliers to get the value in 1 clock. Stuff like that. Then all you worry about is getting data in and out of ram. The fan out is really small and the routing is simpler.
