10 years agoQuartus Router Congestion
Hello all, I have a Cyclone V A9 device (300k LEs) and a big design that fit it 95% ALM 12% Memory bits 37% DSP. 14% of ALM are unavailable due to LAB input limits and wide-signals conflicts so...
10 years agoThat sounds highly inefficient. Can't you insert data during run time? What latency is required? If you don't care about latency then you could re use as much logic s you wanted.
