I am almost certain that my Quartus II web 13.1 program creates RTL schematics with errors in them. (I have not upgraded the installation afterwards because my computer is offline!).
Please see next screencopy that shows the wrong 2'h1 and 2'h2 markings (they should be exchange) in the Mux4to1 example. Also the RTL schematic of the 4to2 Mux makes no sense to me. Can you please explain me if I'm correct and if not how to intepret the
- AVanB3
Hereby I hope to attach the right information you asked KhaiY. I attach 2 packed files. The file output files is from that Altera 13.1 map.
Hope they shed a light on solving this BRAM 16x2 question.
Albert.
- AVanB3
I notice it only attached the one file upload so I try to upload the Output files file again.
Thanks!
Albert.
- KhaiChein_Y_Intel
Hi Albert,
In the .map.rpt file you have attached, there are two error messages:
Error (12006): Node instance "U0" instantiates undefined entity "BRAM_16x1S" File: J:/altera/13.1/bram_16x2.vhd Line: 46
Error (12006): Node instance "U1" instantiates undefined entity "BRAM_16x1S" File: J:/altera/13.1/bram_16x2.vhd Line: 49
The error indicates that the BRAM_16x1S HDL file is not added to the Project. I compile the qar file, there is no BRAM_16x1S file in the project directory. Can you check if you have add this file to the project? You may check from the Project Navigator.
KhaiY
- AVanB3
Hi KhaiY, the vhdl file contains a component named BRAM_16x1S as part of the archive BRAM16x2 archtecture. It works splendidly as it is in Xilinx ISE 14.6. But Quartus 13.x fails to compile this same vhdl file. This is that file:
-- Company:
-- Engineer:
-- Create Date: 22:57:22 05/09/2020
-- Design Name:
-- Module Name: BRAM_16x2 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
--BRAM_16x2 blz.194
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity BRAM_16x2 is
port (q_out : out std_logic_vector (1 downto 0);
write_en : in std_logic;
clk: in std_logic;
d_in: in std_logic_vector (1 downto 0);
a_in: in std_logic_vector (3 downto 0));
end BRAM_16x2;
architecture BRAM_arch of BRAM_16x2 is
component BRAM_16x1S is
port(O : out std_logic;
D: in std_logic;
A3, A2, A1, A0: in std_logic;
WE, W_CLK: in std_logic);
end component;
begin
U0: BRAM_16x1S port map (O =>q_out(0), WE =>write_en, W_CLK =>clk, D =>d_in(0),
A0 =>a_in(0), A1 =>a_in(1), A2 =>a_in(2), A3 =>a_in(3));
U1: BRAM_16x1S port map (O =>q_out(1), WE => write_en, W_CLK => clk, D =>d_in(1),
end BRAM_arch;
I'll add it hereby as attachement too.
Thanks again for taking the time to look into the problem!
Albert.
- KhaiChein_Y_Intel
Hi Albert,
The BRAM_16x2vhd is instantiating the BRAM_16x1S but there is no BRAM_16x1S HDL file in the archive.
Could you provide BRAM_16x1S ?
KhaiY
- AVanB3
Hi KhaiY, that is the problem, why it probably isn't working in Quartus II. But this file as it is, works splendidly in Xilinx ISE 14.6 without any problem! That is why I asked this question. I just noticed that it only works in Xilinx ISE 14.6 when a higher type FPGA is chosen. Earlier Xilinx FPGA's probably were unable to work as BRAM configurated FPGA's.
Because a Xilinx Spartan 3E failed to compile this BRAM file that works splendidly on a Xilinx Zynq XA 7z010 FPGA as it was given in the above mentioned BRAM_16x2 vhdl file from the book : PLD BASED DESIGN WITH VHDL by Vaibbhav Taraate.
I know too little yet about the Quartus II and Xilinx ISE programs to know why the file creates problems in Quartus II. But I guess it has to do with what version of program is used.
Thanks!
Albert.
- KhaiChein_Y_Intel
Hi Albert,
I appreciate your explanation on the issue, but unfortunately we are not in liberty to discuss on our FPGA software especially in comparison to our competitor products.
I am happy to address the implementation challenges that is related to our FPGA software. In general, all the source files need to be added to the project directory for successful compilation. In this case, the software reports that the source file for BRAM_16x1S is missing in the project directory. You have to add the source file for this BRAM_16x1S if you want to instantiate it in the bram_16x2.vhd file.
KhaiY
- AVanB3
Understood KhaiY. But since the current file worked in Xilinx without the BRAM_16x1S file, it wasn't needed and therefore not given in the mentioned book. And if I had that file I wouldn't know how to add it to the project anyhow. Especially if it can't be added to the existing vhdl file. I already tried to do that previously to get it compiled in Quartus until I found out that it already worked in its present version in Xilinx ISE 14.6.
Best regards.
Albert.
- KhaiChein_Y_Intel
Hi Albert,
In the Intel Quartus Prime software, you have to add the logic design files that contain the logic that implements your design into the Project. The source file can be in HDL(.v/.vhd/.sv), Verilog Quartus Mapping (.vqm) design files and Platform Designer (Standard) system (.qsys). It this case, it is not possible to instantiate BRAM_16x1S without the source file that describes how BRAM_16x1S works in the design.
To add the files into the Project
1) Click on Project > Add/Remove Files in Project
2) Click on ... icon to add the files
3) Ok
KhaiY
- AVanB3
Thanks KhaiY, I will try your much appreciated explanation later on today when I'm back from my job. I hope that I will manage to get the BRAM file running in Quartus this time.
Have a great day!
Albert.
