zebadeediddly's avatar
zebadeediddly
Icon for New Member rankNew Member
6 hours ago
Unable to configure new license server
I am struggling to get our Quartus license to work on a new server. We had to replace the old server as the operating system is going out of support.
A new license file has been requested and recievd which matches the mac address of the new server
In the license file it references alterad and mgcld. If i install the flexLM version of the license manager then alterad is present but mgcld is not. I have tried commenting that line out - still doesn't work.
If I change the license manager type and install the siemens one, that has no alterad and my understanding is that I should be changing the license file to use saltd instead of mgcld - I have done that, it still doesn't work.
I guess I must be doing something wrong. I have setup numerous flexlm and other types of license servers and do not usually encounter many issues but this is really causing us problems.
Do you have anywhere that will guide me through what I need to do stet by step?
The documentation in the link from the license file (https://docs.altera.com/r/docs/683472/25.3/altera-fpga-software-installation-and-licensing/setting-up-a-license-file-in-the-license-server) suggests that the license manager should have both alterad and saltd executables, but as i say, neither flex or siemens license managers install both.
I havr tried installing both license managers and referencing alterad and mgcld in their respective loctions but that did not work
Also - I just tried to get a new lic file to see if it would then ref the correct exes for either of the lic managers and I have just been emailed no less than 5 license files, Unsure what they are all for?
This is the error message when I attempt to start the server
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license has been changed
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    There are a few distinct issues tangled together here — let me untangle them.
    1. Which daemons belong in your license file VENDOR lines
    You need both alterad and saltd in the VENDOR lines, and they can co-exist on the same server. You can only have one vendor daemon running at a time of each type — for example, alterad and saltd can co-exist, but you cannot have two running daemons of alterad. Altera FPGA Software Installation and Licensing
    The daemon-to-product mapping is:
    2. The mgcld situation — critical point
    If the VENDOR line mentions mgcld, you must manually change it to saltd. mgcld is no longer supported in the Questa Altera FPGA Edition version 2024.1 and later. Altera FPGA Software Installation and Licensing
    However — and this is the part that trips most people up — only change the VENDOR line, not the INCREMENT lines. Do not change any of the INCREMENT lines. Leave the INCREMENT lines with the original vendor daemon name (mgcld). Setting up a License File in the License Server
    So your license file VENDOR section should look like this:
    VENDOR alterad /path/to/alterad [port=]
    VENDOR saltd /path/to/saltd [port=]
    …with all INCREMENT lines left exactly as received.
    3. Where to get the daemon executables
    You don't need to install a separate Siemens license manager to get both daemons. To support network licensing, the Altera FPGA software requires FLEXlm license manager server software version 11.19.5.0 or later. The installation process for Quartus Prime software installs FLEXlm version 11.19.5.0. You should also verify that the FLEXlm software version on the license server is 11.19.5.0 or later. Upgrading the FLEXlm License Manager Server Software
    The Quartus Prime installation provides lmgrd and alterad:
    • Windows: \quartus\bin64\alterad.exe and lmgrd.exe
    • Linux: /quartus/linux64/alterad and lmgrd
    For saltd, upgrade to the Siemens FlexLM (SALTD) daemon from the download page. Error : FLEXlm version of vendor daemon is too old You only need to drop the saltd binary into a known path and reference that path in the VENDOR line — you do not need to run the full Siemens license manager installer.
    4. Step-by-step: setting up the license file on the server
    1. Save license.dat in the preferred location:
      Windows: :\flexlm Linux: /usr/local/flexlm/licenses Setting up a License File in the License Server
    2. Edit the SERVER line to include the correct hostname and port:
      If the license server uses Windows, specify the port number for the licensing manager. Choose a number outside of the 27000–28000 range, and unique on the machine. In Linux systems, the FLEXlm license manager automatically chooses a free port between 27000 and 27009. Setting up a License File in the License Server
    3. Edit the VENDOR lines:
      • Change mgcld → saltd on the VENDOR line only
      • Set the correct path to each daemon executable
      • Optionally specify a static port per daemon (recommended if you have a firewall)
      Example: SERVER myServer 0123456789ab 1800
      VENDOR alterad ./alterad port=1801
      VENDOR saltd ./saltd port=1802 Setting up a License File in the License Server
    4. Leave all INCREMENT lines untouched.
    5. Start the server:
      At a command prompt, type:
      Windows: \bin64\lmgrd -c \path\to\license.dat
      Linux: /linux/lmgrd -c /path/to/license.dat Launching the Licensing Server
    5. The "Cannot connect to license server" error
    This error almost always means one of three things: lmgrd hasn't been started successfully, the port@host string the client is using doesn't match what's in the license file, or a firewall is blocking the port. On Windows in particular, Quartus Prime software release version 12.0 and later does not recognise a FLEXlm license server specification that does not contain an explicit port number (e.g., @mylicsrv). To resolve this, specify an explicit port number (for example, 27000@mylicserv on Windows clients). The Quartus II software does not recognize a FLEXlm license server specification without an explicit port number
    Also verify the lmgrd daemon itself started cleanly by checking the log file. If you change the license file, you must reread the license file or restart the license server before you can run the Quartus Prime software again. Rereading an Existing License File on a License Server
    6. The multiple license files you received
    This is expected behaviour when you have licenses for multiple software versions assigned to one server. An Altera license file contains FEATURE and INCREMENT lines with the same product name but different maintenance dates if multiple floating network licenses for different software versions are assigned to a single computer or triple-redundant server group. FEATURE lines have the latest maintenance date; INCREMENT lines are for the same product with older maintenance dates. The use of FEATURE and INCREMENT lines allows older and newer Altera licenses to be hosted on a single license server. Why does my license file contain FEATURE and INCREMENT lines with the same product name? You should use the file that was generated most recently (highest maintenance date on the FEATURE lines), or if the SSLC gave you separate files for different entitlements, if you have an Altera FPGA software license and Questa Altera FPGA Edition software license and also have other Siemens EDA QuestaSim software licenses, you can either merge all of them into a single file or put all Siemens EDA QuestaSim software licenses in a single file. Altera FPGA Software Installation and Licensing
    Quick sanity check after getting the server running:
    Use the quartus_sh --check_license command to get information about your Quartus Prime licenses Checking Quartus® Prime License Configuration — it will show you the detected NIC IDs, license source, mode, and a full list of licensed products, which is the fastest way to confirm everything is wired up correctly.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
  • Running on Windows.....
    Ok, so i installed flex license manager and the siemens one.
    I configured the license service using the lmtools within the flexlm install. Configured as follows
    Then before starting the service i edited the license file like this
    SERVER ServerName MacAddress 1800
    VENDOR alterad "C:\flexlm\alterad.exe" PORT=1801
    VENDOR saltd "C:\Program Files\Siemens\License Server\saltd.exe" PORT=1802
    Surely that is all that is needed?
    Starting the license server gives
    Status
    Flexible License Manager status on Fri 10/16/2026 10:01
    [Detecting lmgrd processes...]
    License server status: mailto:1800@ServerName
    License file(s) on ServerName: C:\flexlm\Quartus.dat:
    port or hostname in the license file has been changed.
    Server name: IPAddress
    License path: mailto:1800@ServerName
    FlexNet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused"
    I did notice on that output it has the server name as the ip address - i did try and change
    to
    SERVER IPAddress MacAddress 1800
    But i just get the same issue
