How can you create a .vqm file or equivalent in Quartus Prime Standard 23.1?
I am trying to send my design without sending the source HDL design files, and I have been able to create a .vo file, but that is only used for simulation. I want to be able to synthesize and compile a new design that incorporates my exported design.
I have tried using the quartus_eda tcl command, but I get errors when I try to invoke it in any way other than through the gui.
Most of the support that I have seen targets Quartus Prime Pro version, but the device that I am targeting (Cyclone IV) is not supported in Quartus Prime Pro.
Any help would be greatly appreciated.
If I understand correctly, you want to share your design without giving the source file. Which is why you want to create the .vqm. Let me know if my understanding is incorrect?
Is that fine for you to exploring export partition instead? https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/exporting-compilation-results.html
Otherwise, you will need the synplify pro as describe in
