How can you create a .vqm file or equivalent in Quartus Prime Standard 23.1?
- 1 year ago
If I understand correctly, you want to share your design without giving the source file. Which is why you want to create the .vqm. Let me know if my understanding is incorrect?
Is that fine for you to exploring export partition instead? https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/exporting-compilation-results.html
Otherwise, you will need the synplify pro as describe in
Since the error is complaining about license, do you know if you already have full subscription license? If that fine to take a screenshots of it, tools -> license setup?
Yes, I have the full version, and so does the external vendor.
The issue appears to be with a license that is used for some encrypted IP within our design.
Is the project that is importing the design partition also required to have this license, even though the partition has already been synthesized?
I unfortunately cannot share the screenshot.
