13 years agoDetecting preamble
Hello, I am trying to write a program to detect preamble of the attached signal. I am getting "error 10500:VHDL syntax error" for following code in Quartus. Can anyone correct me? As I am new to VHDL, I am unable to find it :cry:
Thanks in advance Note: we are interested in only 8 bit preamble and 2 bit data (not whole 112 bit data). library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; package preamble is constant NROF_CYCLES_per_interval: integer :=25; constant NROF_INTERVALS: integer :=18; constant NROF_ALL_CYCLES_MAX: integer :=NROF_CYCLES_per_interval*NROF_INTERVALS; Variable cycle, all_cycles, nrof_cycles: integer :=0; type Input_values is ARRAY (nrof_cycles) of integer; function increment_cycle return integer; function process1 (valu :integer) return integer; function increment_all_cycles return integer; function add_to_all_cycles (a: integer) return integer; function contents_process(contents: integer) return integer; end preamble; package body preamble is function increment_cycle return integer is begin if (cycle +1 > nrof_cycles) then return 1; else return cycle+1; end if; end increment_cycle; function process1 (values: integer) return integer is variable myinput_values : input_values; Variable SUM_A,SUM_B: integer :=0; begin cycle:=increment_cycle; nrof_cycle:=nrof_cycle+1; SUM_A:=SUM_A+values; if(nrof_cycles> NROF_CYCLES_per_interval) then SUM_B :=SUM_B + myinput_values[cycle]; contents_I1:=SUM_A-SUM_B; contents_process(contents_I1); end if; myinput_values[cycle]:= values; end process1; function increment_all_cycles return integer is begin if (all_cycles +1 > NROF_ALL_CYCLES_MAX) then return 1; else return all_cycles+1; end if; end increment_all_cycles; function add_to_all_cycles (a: integer) return integer is begin if (all_cycles –a<1) then return (all_cycles-a + NROF_ALL_CYCLES_MAX); else return all_cycles-a; end if; end add_to_all_cycles; function contents_process(contents: integer) return integer is begin all_cycles:=increment_all_cycles; Contents_values[(all_cycles):=contents; if (nrof_cycles>NROF_ALL_CYCLES_MAX) then for i in 1 to 18 loop Interval_values(i):=Contents_values(add_to_all_cycles (NROF_CYCLES*(I-1))); end loop; end if; end contents_process end preamble Libraray IEEE; Use IEEE.std_logic_1164.all; Use work.preamble.all Entity preamble_det is Port(cycle: in std_logic; values: in std_logic; contents_I1: out std_logic; Interval_values : out Input_values; ); End preamble_det Architcture behave of preamble_det is Begin end behave;
