The program below compile with quartus ii for cyclone IVE.
but for confirmation: does it transfer 906 samples of 14 bit data from input to output as soon as significant bit is detected??
library ieee;
use ieee.std_logic_1164.all;
entity preamble_det is
port( clk: in std_logic;
detection: out std_logic;
input: in std_logic_vector(13 downto 0);
output: out std_logic_vector(13 downto 0));
end preamble_det;
architecture behave of preamble_det is
type bit_bus is array(905 downto 0) of std_logic_vector(13 downto 0);
signal element : bit_bus;
begin
transfer_data: process (clk) --transfer data at each clock
begin
if (clk'event and clk= '1') then
for i in 13 downto 8 loop
if(input(i) = '1') then
detection <= '1'; --significant bit detection
else
exit;
end if;
end loop;
for n in 905 downto 0 loop
element(n)<= input;
output<=element(n);
end loop;
end if;
end process transfer_data;
end behave;
one additional query: can we call a process using label from other process like function if we have multiple processes??
