Thanks for giving me a direction. As per your suggestion I used a Process as follows:
library ieee;
use ieee.std_logic_1164.all;
--declaring global variables
package share is
type input_values1 is array(0 to 25) of integer;
type amplitudearray1 is array(0 to 905) of integer;
type interval_values1 is array(0 to 18) of integer;
end package share;
library ieee;
use IEEE.std_logic_1164.all;
use work.share.all;
entity preamble_det is
Port(clk: in std_logic;
amplitudearray: in amplitudearray1;
interval_values: out interval_values1);
end preamble_det;
architecture behave of preamble_det is
constant nrofcycle_perinterval: integer :=25;
constant nrofinterval: integer :=18;
constant nrofallcycle_max: integer :=nrofcycle_perinterval*nrofinterval;
begin
process(clk)
variable contents_values: amplitudearray1;
variable input_values: input_values1;
variable n : integer;
variable n1 : integer;
variable nrofcycle : integer := 0;
variable cycle : integer := 0;
variable sum_a : integer := 0;
variable sum_b : integer := 0;
variable contents_I1 : integer;
variable allcycles : integer := 0;
variable i : integer;
begin
if (rising_edge(clk)) then
for n in 1 to 905 loop
if ((cycle+1) > nrofcycle_perinterval) then
cycle:= 1;
else
cycle:=cycle+1;
end if;
nrofcycle:=nrofcycle+1;
sum_a:=sum_a+(amplitudearray(n));
if (nrofcycle>nrofcycle_perinterval) then
sum_b:=sum_b+input_values(cycle);
contents_I1:=sum_a-sum_b;
if ((allcycles+1) > nrofallcycle_max) then
allcycles:= 1;
else
allcycles:= (allcycles+1);
end if;
contents_values (allcycles):=contents_I1;
if(nrofcycle>nrofallcycle_max) then
for n1 in 1 to 18 loop
if ((allcycles-(nrofcycle_perinterval*(n1-1)))<1) then
i:= (allcycles-(nrofcycle_perinterval*(n1-1))+nrofallcycle_max);
else
i:= allcycles-(nrofcycle_perinterval*(n1-1));
end if;
interval_values (n1) <= contents_values (i);
end loop;
end if;
end if;
input_values(cycle):=amplitudearray(n);
end loop;
end if;
end process;
end behave;
During running this program either Quartus II 11.0 becomes hang or I got the following errors::
Error: Out of memory in module quartus_map.exe (4097 megabytes used) while running 32-bit Quartus II on a 64-bit OS platform. Please use the 64-bit Quartus II to increase memory capacity.
Error: Current module quartus_map ended unexpectedly
Is there any way to reduce the memory? I checked the same Program in "C programming" where it works fine using 5 functions for each stage.
I read that ""Signal represents interconnection wires that connect component
instantiation ports together whereas Variable is used for local storage of temporary data and visible only inside a process"". But here I am still unable to decide which one I should take as a variable and which one as signal.
Further help will be highly appreciated.
