13 years ago
Detecting preamble
Hello, I am trying to write a program to detect preamble of the attached signal. I am getting "error 10500:VHDL syntax error" for following code in Quartus. Can anyone correct me? As I am new to VHDL, I am unable to find it :cry:
Thanks in advance
Note: we are interested in only 8 bit preamble and 2 bit data (not whole 112 bit data).
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
package preamble is
constant NROF_CYCLES_per_interval: integer :=25;
constant NROF_INTERVALS: integer :=18;
constant NROF_ALL_CYCLES_MAX: integer :=NROF_CYCLES_per_interval*NROF_INTERVALS;
Variable cycle, all_cycles, nrof_cycles: integer :=0;
type Input_values is ARRAY (nrof_cycles) of integer;
function increment_cycle return integer;
function process1 (valu :integer) return integer;
function increment_all_cycles return integer;
function add_to_all_cycles (a: integer) return integer;
function contents_process(contents: integer) return integer;
end preamble;
package body preamble is
return integer is
begin
if (cycle +1 > nrof_cycles) then
return 1;
else
return cycle+1;
end if;
end increment_cycle;
function process1 (values: integer)
return integer is
variable myinput_values : input_values;
Variable SUM_A,SUM_B: integer :=0;
begin
cycle:=increment_cycle;
nrof_cycle:=nrof_cycle+1;
SUM_A:=SUM_A+values;
if(nrof_cycles> NROF_CYCLES_per_interval) then
SUM_B :=SUM_B + myinput_values[cycle];
contents_I1:=SUM_A-SUM_B;
contents_process(contents_I1);
end if;
myinput_values[cycle]:= values;
end process1;
return integer is
begin
if (all_cycles +1 > NROF_ALL_CYCLES_MAX) then
return 1;
else
return all_cycles+1;
end if;
end increment_all_cycles;
return integer is
begin
if (all_cycles –a<1) then
return (all_cycles-a + NROF_ALL_CYCLES_MAX);
else
return all_cycles-a;
end if;
end add_to_all_cycles;
return integer is
begin
all_cycles:=increment_all_cycles;
Contents_values[(all_cycles):=contents;
if (nrof_cycles>NROF_ALL_CYCLES_MAX) then
for i in 1 to 18 loop
Interval_values(i):=Contents_values(add_to_all_cycles (NROF_CYCLES*(I-1)));
end loop;
end if;
end contents_process
end preamble
Libraray IEEE;
Use IEEE.std_logic_1164.all;
Use work.preamble.all
Entity preamble_det is
Port(cycle: in std_logic;
values: in std_logic;
contents_I1: out std_logic;
Interval_values : out Input_values;
End preamble_det
Architcture behave of preamble_det is
Begin
end behave;
    I don't think your code does what you wanted it to do.
    Remember that all the lines in the "if (clk'event and clk= '1')" will be executed within the same clock cycle. So basically, at each clock cycle the 906 elements of your array are all filled with the same value: the input vector at the rising edge.
    output<=element(n);
    This line is also executed 906 times, so the first 905 ones will be ignored and output will simply be fed with the value element(905), which is the value of input on the previous rising edge. You created a two cycle delay, and Quartus will optimize it by removing the first 905 of your array, which are useless.
    detection <= '1'; --significant bit detection
    detection is never set to 0 anywhere in your code. It will start at an undefined value at power up (I'm not sure Quartus will set it to 0, but it doesn't need to do this to be compliant with the VHDL specification) and once set to 1 it will never change back. If Quartus is smart enough it may decide to optimize you code by just setting detection at a fixed value of 1 (but I haven't tested this).
    --- Quote Start ---
    one additional query: can we call a process using label from other process like function if we have multiple processes??
    --- Quote End ---
    you can't "call" a process, a process is a piece of hardware that is always there. You can use functions and procedures, but even there when you use them it isn't a "call" as you understand it in software, it is an instantiation. Each "call" will generate a new piece of hardware.
    As other replies suggested, you should start with a book about logic design and VHDL. Some people gave some good references on this forum, a search will probably help.
