Hello FvM,
I tried different way using Functions as follows::
library ieee;
use ieee.std_logic_1164.all;
--making global variables as these variables are used by 5 functions in my case
package share is
variable nrofcycle : integer := 0;
variable cycle : integer := 0;
variable sum_a : integer := 0;
variable sum_b : integer := 0;
variable contents_I1: integer;
variable allcycles : integer := 0;
variable i : integer;
variable n : integer;
variable n1 : integer;
constant nrofcycle_perinterval: integer :=25;
constant nrofinterval: integer :=18;
constant nrofallcycle_max: integer :=nrofcycle_perinterval*nrofinterval;
type input_values1 is array(0 to 25) of integer;
variable input_values: input_values1;
type amplitudearray1 is array(0 to 905) of integer;
variable contents_values: amplitudearray1;
variable y: amplitudearray1;
type interval_values1 is array(0 to 18) of integer;
function process1 (values: integer) return integer;
function increment_cycle return integer;
function contents_process(content:integer) return integer;
function increment_allcycle return integer;
function subfromallcycle(a: integer) return integer;
end package share;
library ieee;
use IEEE.std_logic_1164.all;
use work.share.all;
entity preamble_det is
Port(clk: in std_logic;
amplitudearray: in amplitudearray1;
interval_values: out interval_values1);
end preamble_det;
architecture behave of preamble_det is
function process1 (values: integer) return integer is
begin
cycle:=increment_cycle;
nrofcycle:=nrofcycle+1;
sum_a:=sum_a+values;
if (nrofcycle>nrofcycle_perinterval) then
sum_b:=sum_b+input_values(cycle);
contents_I1:=sum_a-sum_b;
contents_process(contents_I1);
end if;
input_values(cycle):=values;
end process1;
function increment_cycle return integer is
begin
if ((cycle+1) > nrofcycle_perinterval) then
return 1;
else
return cycle+1;
end if;
end increment_cycle;
function contents_process(contents_I1:integer) return integer is
begin
allcycles:=increment_allcycle;
contents_values (allcycles):=contents_I1;
if(nrofcycle>nrofallcycle_max) then
for n1 in 1 to 18 loop
i:=subfromallcycle(nrofcycle_perinterval*(n1-1));
interval_values (n1) := contents_values (i);
end loop;
end if;
end contents_process;
function increment_allcycle return integer is
begin
if ((allcycles+1) > nrofallcycle_max) then
return 1;
else
return (allcycles+1);
end if;
end increment_allcycle;
function subfromallcycle(a: integer) return integer is
begin
if ((allcycles-a)<1) then
return (allcycles-a+nrofallcycle_max);
else
return allcycles-a;
end if;
end subfromallcycle;
begin
process(clk)
begin
if (rising_edge(clk)) then
for n in 1 to 906 loop
y:= process1 (amplitudearray(n));
end loop;
end if;
end process;
end behave;
Then, I get following errors::
Error (10511): VHDL Qualified Expression error at preamble.vhd(60): contents_process type specified in Qualified Expression must match void type that is implied for expression by context
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 275 megabytes
Error: Processing ended: Wed Sep 05 11:15:02 2012
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Could you please help me to correct it?
