12 years agoBuilding an SPI Decoder into Altera
I am working on a project which requires interfacing between a Microcontroller and an Altera FPGA. I'm using an Arduino UNO and DE0Nano Cyclone IV. The Arduino sends a 64bit word via SPI into the Altera. This word has been verified using a Logic Analyzer, and it seems to be stable and correct. In order to read the 64 bits, I am loading everything into a shift register. This procedure works as well since my outputs are correct. The first process in the code snippet below reads the data through SPI, making sure the Selector is active low and reading on the RE of the clock. The second process decodes the 64 bit word into the specific outputs I need. It does this at the end of a data transmission, when the Selector is going back to the idle state High. The issue I'm running into is when the circuit is idle, when SPI is not running in the Microcontroller. From the code, since SPI_Sel is High and SPI_Clk is not operating, I expect the shift register to be set to 0 and no value should change. However, this is not the case and I get a flickering in my values. If I remove the line where I load into the shift_reg64(63 downto 0), this flickering stops and obviously nothing happens. Since, the flickering stops, I believe that data is being loaded and read from the shift register without it being ready. Does anyone have any idea of what may be causing this? Thank you very much! Below is the code I'm referencing.
process (SPI_Clk, SPI_Data, SPI_Sel, shift_reg64) begin
if rising_edge (SPI_Clk) then
if (SPI_Sel = '0') then
--shift data in and load new
shift_reg64(63 downto 0) <= shift_reg64(62 downto 0) & SPI_Data;
end if;
end if;
end process;
process (SPI_Sel, shift_reg64) begin
if rising_edge(SPI_Sel) then
outA <= "000" & shift_reg64(60 downto 32);
outB <= "000" & shift_reg64(28 downto 0);
SEL_h <= shift_reg64(63 downto 61);
SEL_l <= shift_reg64(31 downto 29);-
end if;
end process;
