12 years agoYou're getting close;
1. Add logic to detect the rising-edge of SPI clock Hint: you can create a single clk period pulse by routing the synchronized spi_clk output through a register, and then using a gate, eg., or, and, xor, with the synchronized and delayed synchronized signal. Call this spi_clk_rising ('cause later you may need an spi_clk_falling version :) ) 2. Use the rising-edge pulse as an enable to your shift-register, i.e., in the code above, use
process (Clk, Reset) begin
if Reset = '1' then
shift_reg64 <= (others => '0');
elsif rising_edge(Clk) then
if (spi_rising_edge = '1') then
shift_reg64(63 downto 0) <= shift_reg64(62 downto 0) & SPI_Data;
end if;
end if;
end process;
Cheers, Dave
