12 years agoOk, this is my newest status. I built a state machine to make the SPI_Clk into a regular signal and this is what I came up with:
process (Clk, Reset) begin
if Reset = '1' then
shift_reg64 <= x"0000000000000000";
elsif rising_edge(Clk) and SPI_Clk = '1' then
shift_reg64(63 downto 0) <= shift_reg64(62 downto 0) & SPI_Data;
end if;
end process;
process (SPI_Sel) begin
if rising_edge(SPI_Sel) then
outA <= "000" & shift_reg64(60 downto 32);
outB <= "000" & shift_reg64(28 downto 0);
SEL_h <= shift_reg64(63 downto 61);--"000";
SEL_l <= shift_reg64(31 downto 29);--"000";
end if;
end process;
This looks pretty much the same, but in my top-level .bdf I'm running the SPI clock straight from GPIO through two D-FFs in series which are clocked with the 50MHz clock. The output of the second D-FF goes into the SPI decoder from the code above as SPI_Clk. I believe now this should be working right, but somehow it still isn't!! If anyone can see where I went wrong, I'd deeply appreciate it! Thanks!!
