14 years ago
Best way to code flop w/asynch reset?
Hi - I've lots of experience in Verilog, but am learning VHDL.
Question: Is this...
process(clk,rst_l) begin
if rst_l = '0' then
sig <= '0';
elsif rising_edge(clk) then
sig <= expression;
end if;
end process;
the best way to do the equivalent of
always @(posedge clk or negedge rst_l) begin
if (!rst_l) sig <= 0;
else begin
sig <= expression;
end
end
(i.e., flop with asynch reset)
I'm asking because in Verilog it's sort of by convention that if you do it -just that way- then all the synthesizers infer you want an asynch flop and the else expression is clocked. I want to make sure I'm doing it the most general way (i.e., least likely for a synth to mis-interpret) for VHDL.
THANKS!
/j
