11 years agoBest approach for creating clock sources please?
Hello again and more inane questions from yours truly!
I have a design which relies on many different clock sources: A lot of inter-dependent timing going on. What therefore is the best (or 'proper') approach to creating many different clocking sources (from the same basic clock source input of course). I know it is not 'good practice' to gate clocks to create another clock which is then used to clock say a latch or a register etc. So, what is considered a good / acceptable clock source? The output of a state machine perhaps? The output of a counter? Any guidelines / comments / suggestions much appreciated! I include below VHDL of something I have written that creates an 8MHz clock from my 24MHz source:
proc_8MHz : PROCESS (nPowerSettleDelay, M24MHz)
BEGIN
IF nPowerSettleDelay='0' THEN
uM8MHz <= '1';
u_nM8MHz <= '0';
Next_State <= State_1;
ELSIF RISING_EDGE(M24MHz) THEN
CASE Next_State IS
WHEN State_1 =>
Next_State <= State_2;
uM8MHz <= '1'; -- 1
u_nM8MHz <= '0'; -- 0
WHEN State_2 =>
Next_State <= State_3;
uM8MHz <= '0'; -- 0
u_nM8MHz <= '1'; -- 1
WHEN State_3 =>
uM8MHz <= '0'; -- 0
END CASE;
END IF;
END PROCESS proc_8MHz;
Is it 'safe' then to use either the uM8MHz or the nM8MHz signal as clock sources? Cheers again all, Andy
