11 years agoTaking for example my last post, I have created an 8MHz clock enable based on my common 24MHz clock source.
When the enable is true, any process such as:
proc_8MHz_freq : PROCESS (M24MHz)
BEGIN
IF RISING_EDGE(M24MHz) THEN
IF en_uM8MHz='1' THEN
--some_counter + 1
END IF;
END IF;
END PROCESS proc_8MHz_freq;
Here, some_counter will +1, not a frequency of 8MHz, rather it will see a bust of M24MHz clocks for the 8MHz enable period. This is obvious and not what I want to have happen with some_counter. Is there an elegant way to better create the en_uM8MHz enable signal such that only ONE clocking event drives some_counter? Thanks again, Andy
