11 years ago --- Quote Start --- I know it is not 'good practice' to gate clocks to create another clock which is then used to clock say a latch or a register etc. So, what is considered a good / acceptable clock source? The output of a state machine perhaps? The output of a counter? --- Quote End --- The only good clock is either a real clock or the output of a PLL, thats it. A state machine output and counter output are the same thing - a register, and these are bad. Using logic to create a clock is bad. For what you are doing, you want clock enables. Ie. the enable is high for one clock in a number of clocks, and you clock all your logic using the same system clock. And then your logic looks like this:
process(clk)
begin
if rising_edge(clk) then
cnt <= cnt + 1;
div_by_2 <= cnt (0);
if cnt(1 downto 0) = "00" then
div_by_4 <= '1';
else
div_by_4 <= '0';
end if;
if div_by_2 then
--stuff happens at half the system clock
end if;
if div_by_4 then
--stuff happens at 1/4 of the system clock
end if;
--etc
end if;
end process;
