11 years agoThe following code:
signal cnt : unsigned(2 downto 0) := "000";
signal div_by_2, div_by_4, div_by_8 : std_logic;
process(clk)
begin
if rising_edge(clk) then
cnt <= cnt + 1;
div_by_2 <= cnt(0);
if cnt(1 downto 0) = 0 then
div_by_4 <= '1';
else
div_by_4 <= '0';
end if;
if cnt = 0 then
div_by_8 <= '1';
else
div_by_8 <= '0';
end if;
if div_by_2 then
--do something every 2 clocks
end if;
if div_by_4 then
-- do something every 4 clocks
end if;
if div_by_8 then
-- do something every 8 clocks
end if;
end if;
end if;
Is functionally the same as, and will produce the same hardware as this code:
process(clk)
begin
cnt <= cnt + 1;
end if;
end process;
process(clk)
begin
div_by_2 <= cnt(0);
end if;
end if;
process(clk)
begin
div_by_4 <= '1';
else
div_by_4 <= '0';
end if;
end if;
end if;
process(clk)
begin
if cnt = 0 then
div_by_8 <= '1';
else
div_by_8 <= '0';
end if;
end if;
end if
process(clk)
begin
if div_by_2 then
end if;
end if;
end if;
process(clk)
begin
if div_by_4 then
end if;
end if;
end if;
process(clk)
begin
if div_by_8 then
end if;
end if;
end if;
