11 years ago
Basic Problems with altlvds_rx ipcore on CycloneV
Dear everyone, I have to receive LVDS data stream based on altlvds_rx on cycloneV device. LVDS data pairs are 500Mbps with accompany 250MHz clock(DDR mode). I set following parameters in the ipcore:
deserialization factor: 10
data rate: 500Mbps
clock frequency: 250MHz
phase alignment of rx_in to rx_inclock: 90.0
At the meantime I also set following constraint in sdc:
create_clock -name lvdsrx_inclk -period 4.000 -waveform { 0.000 2.000 } [get_ports "rx_inclock"]
After compilation, I find that there are hold timing errors inside the altlvds_rx ipcore, check the attachment.
The strange thing is that all the problem is inside the altlvds_rx itself, and I have no idea how to make a change.
Note that I have already set fitter to optimize hold timing for all paths.
Question:
1. Should I create lvdsrx_inclk clock in SDC? This is required or not?
2. If yes, how to correct this timing error?
