11 years agoAvalon BFM - Test Program
I just succesfully generated my first Avalon BFM testbench with Qsys 14. I have a component that consist of my avalon entity and an additional library file that contains some system wide constants. The Qsys "generate" procedure generated a big file structure with a testbenchfile that I suppose to use in some kind of "test program" that uses the BFM API described in the document "Introduction to Avalon Verification IP Suite". I'm currently stuck where I have to set up a little tcl script that compiles my testbench design in modelsim. The script looks like this and is based on the BFM example found here: http://www.altera.com/support/examples/design-flow/exm-avalon-verification-ip.html (http://www.altera.com/support/examples/design-flow/exm-avalon-verification-ip.html)
# setup variables for simulation script
set system_name ads1158_bfm_test_tb
set QSYS_SIMDIR $system_name/simulation
set TOP_LEVEL_NAME tb
source $QSYS_SIMDIR/mentor/msim_setup.tcl
# compile system
dev_com
com
# compile testbench and test program
# vcom test_program_pkg.vhd
# vcom test_program.vhd
# vcom tb.vhd
# load and run simulation
# elab_debug
# do wave.do
# run 50ns
# alias to re-compile changes made to test program, load and run simulation
# alias rerun {
# elab_debug
# do wave.do
# run 50ns
If I call this in modelsim, the output is as follows:
do run_ads_1158_bfm_simulation.tcl
# ads1158_bfm_test_tb
# ads1158_bfm_test_tb/simulation
# tb
# file_copy
# List Of Command Line Aliases
# file_copy -- Copy ROM/RAM files to simulation directory
# dev_com -- Compile device library files
# com -- Compile the design files in correct order
# elab -- Elaborate top level design
# elab_debug -- Elaborate the top level design with novopt option
# ld -- Compile all the design files and elaborate the top level design
# ld_debug -- Compile all the design files and elaborate the top level design with -novopt
# List Of Variables
# TOP_LEVEL_NAME -- Top level module name.
# SYSTEM_INSTANCE_NAME -- Instantiated system module name inside top level module.
# QSYS_SIMDIR -- Qsys base simulation directory.
# QUARTUS_INSTALL_DIR -- Quartus installation directory.
# dev_com
# com
# Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013
# Top level modules:
# --none--
# --none--
# --none--
# Model Technology ModelSim ALTERA vcom 10.1e Compiler 2013.06 Jun 12 2013
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Loading package NUMERIC_STD
# ** Error: (vcom-11) Could not find work.rts_data_transfer.
# ** Error: ads1158_bfm_test_tb/simulation/submodules/ads1158_interface.vhd(39): (vcom-1195) Cannot find expanded name "work.rts_data_transfer".
# ** Error: ads1158_bfm_test_tb/simulation/submodules/ads1158_interface.vhd(39): Unknown expanded name.
# ** Error: ads1158_bfm_test_tb/simulation/submodules/ads1158_interface.vhd(41): VHDL Compiler exiting
# ** Error: /opt/altera/14.0/modelsim_ase/linux/vcom failed.
# Error in macro ./run_ads_1158_bfm_simulation.tcl line 9
# /opt/altera/14.0/modelsim_ase/linux/vcom failed.
# while executing
# "vcom "$QSYS_SIMDIR/submodules/ads1158_interface.vhd" -work ads1158_interface_0 ..."
# ("eval" body line 8)
# invoked from within
# "com" I really don't know, where I should point the modelsim software to into the filestructure that Qsys created by generating my BFM testbench. I guess that modelsim complains that it does not find my little library file (that contains my systemwide constants). I don't know, how I can fix this issue and honestly, I don't know how to proceed from there if it is fixed. I know from the examples that I need an additional program file that actualle calls the BFM API, but i don't know how to implement a small program that e.g. starts the clock of my testbench ticking. Can somebody provide a little guidance on that? And of course a solution for the above shown modelsim error? Thank you! Maik
