--- Quote Start ---
In my point-to-point testbenches I connect the byte-based address to the master, then drop the LSBs and connect the word based address to the slave, and then add a note that this corresponds to the job of the non-existent Avalon-MM fabric.
--- Quote End ---
This seems to be a suitable way..... I read that avalon spec a couple of times during the last years but it seems as if I am always missing something.....
One last question before I start using those BFMs of yours: I asume that it is possible to implement an avalon busstructure, where I provide the aforementinoed avalon master and two avalon slave (the data source and the data sink) components and connect those with your BFMs, right. This data transfer between my avalon master and slave components is something I have to heavy test because in there I somwhere have a bad bug that is annoying to search in the real system with signal tap.
Maik
