17 years ago
about chip planner in Quartus II
I tried to change the placement and routing by Chip planner, and estimate the delay time.
For example, I input a signal to a buffer and then output, the delay time in Chip planner is:
after I generate fan-out connections:
input port to the LE, which is the buffer: 2.590 ns
delay time in LE : 0.2 ns
LE to the output port : 1.695 ns
then, the total delay time from input to output signal should be around 5 ns.
But, when I use oscilloscope to see the delay between the input and output signal, It is around 15 ns.
It is very differnet to the 5 ns of the estimated time.
I dont know if I do something wrong why they are not same.
Thanks for your help.
My Quartus II is version 7.1 Web edition
